Panda (Classic) Charmanda(er) - mania continued......
So having been amused at everyone guessing who have bought Char' I own up, t'was me :nerner:
Obviously having just picked up today I don't really have much to say, but I am a happy bunny. I have many plottings going on in my head as to what to do with it - you'll just have to wait and see what happens in the long term, in the short term gonna pretty much leave it and enjoy panda-life for a bit.
Anyway, everyone like pics over waffling... ;)
Got a lift from Simon in exchange for a full tank of fuel (should have half left still i think lol).
Few hours and a pitstop to eat a Subway for brekkie and then.... A wild Charmander appeared :D
Was not the best weather on the drive back but Char' ran faultlessly
Stopped about halfway home for quick pitstop and to get a pic to share on facebook for all the people guessing what I had bought before it got too dark.
And finally made it home - was mildly amusing getting out the panda to move my alfa forward a touch and practically stamping a hole through the floor cause its such a light pedal compared to the panda.... I hate to think what it would be like going from panda to suzuki as that is way way way lighter pedals than even the alfa.
All 3 fit on the drive, albeit quite close together.. But the garage is empty and Char' will live in there when not being driven - just couldn't be bothered to move all the cars around after being in the car all day.
edit: Just for info in future, links to previous owners
last owner: Didge3 - thread
owner before last: VmanC - thread
Well not had chance to go out and play in the garage much recently..
Managed another few hours today cleaning round the bay a bit.
I know it hardly looks super clean but it was really bad in there so the fact you can see bare metal anywhere at all I'm quite proud of. Sure Didge can confirm I have defo made big difference so far lol.
Spent quite a while trying to clean the airbox up. Happy with the results and also found the little mechanism that opens the flap once warm was broken so it's been constantly sucking hot air from the manifold - just took the flap off for now. Stuck in new air filter while there and a fuel filter too. Will do oil and coolant change once bay is cleaned.
Drivers side of bay is mostly clean now but as you can see I still need to do passenger side.
Other than that it had a flat battery so couldn't run it as planned today, is on the charger now so soon. And one of the rear tyres is flat. Nevermind I think I'm gonna change the wheels soon just not sure what with yet.
So I know i said i wasn't taking it out until spring but i had it out the garage to run it a bit - so i took it for a little run-around, the weathers been nice after all. Need to give him a proper wash now though, will get to is soon. Still runs great but was a nightmare to get started - i think its just cause i changed the fuel filter though (i hope lol), i had to suck fuel up and fill the inline filter up and it still wouldn't start until i chucked some straight down the carb - started fine several times after though so think all is well.
Engine bay definitely looks cleaner (y) Just need to get that engine cleaned up now :rolleyes: I always wanted to get the cam cover all clean but never got round to it :eek:
The airbox flap got stuck before so I jammed it to the cold position, maybe that's what caused to to eventually break... :confused:
Trouble starting is a strange bug Char' has, she doesn't like the cold, the carb always seems to play up a bit and I could never understand why, spark is good and the coil is practically new but the carb could definitely do with a rebuild depending on how long you plan on keeping the 750 in there.
tbh the engine is about as clean as its gonna get without taking manifolds off etc. I'm conflicted as to what to do with it in general atm - I know its staying as is for at least the next summer so i can drive it around and go to some meets/shows in him but after that i'm not really sure whether I am gonna leave it as a carb'd 750 or whether to go a bit silly and make it completely and unnecessarily fast (which was always my plan originally) - time will tell.
The starting thing, as far as i can tell is a fuel thing - when i was trying to start it there was no fuel passing through the filter, I turned it over for ages to give it the pump a chance to pull some fuel up but none ever came up into the filter. So i took pipe off the pump, sucked fuel up so there was fuel in the filter and then stuck pipe back on and spat what i had in my mouth in the carb, pretty much fired up straight away then. So maybe the pump is just getting tired - and once started the extra vacuum of the engine helps pull a constant stream better than when just turning over... I dunno, its just a thought, I'm not that good at carb'd engines - everyone in here seems to think they are less complicated than injection but to me carbs are just witch craft lol - really must do some learning on that front!!
Weird, maybe it is the new filter as you suggested then...
Best option would be to turbo the 750 :devil:, short stroke, tiny pistons, turn it into a high revving turbocharged monster (well a small one... :eek:) Would be pretty unusable on the roads and be tricky to setup but very unique.
Or go with the boring sensible idea and put a p85 in it (y)
What a commitment...., True Panda owner.
Next time when you will be trying to start the engine with no luck, remove fuel filler cap and try to start (not drive) without in case there is air lock.
Mmmmm, possible blocked breather - that could be a possibility, that hadn't even crossed my mind, good call
OK so had a little mess today and its defo not fuel that is causing the poor start that defo works fine it turns out. So if its not fuel it has to be spark thats weak - well i remember Dom saying he changed the coil in his thread, does seem that long ago and certainly the coil itself looks pretty much brand new. I have also put new plugs and leads on the car recently so not that... So today took the dizzy cap off and my mind went 'AHA!' when i looked in there, the contacts were mighty crusty (what there is left of them). Cleaned them up, stuck it on and it now starts pretty much on the button. Have ordered a replacement as although it is working now its clearly near end of its life.
I have also got one of them ignition modules i seen a few members have fitted, one of these. I got a little confused by the wiring - yup to me injection really makes more sense, not really sure why there is a wire coming from both +ve and -ve posts of the coil across to the distributor, and there is another (non standard wire) there i have no idea what is, well i think its for the aftermarket tacho but i not really investigated where said wire goes but thats my theory without doing any testing - clearly unplugging it and seeing if the tacho still works would tell me but not even done that, left it for another day - prob wait for the new cap to turn up before i mess more.
Weather has been on the up though so hopefully get him out properly soon (y)
Yup as you said I replaced the coil somewhere within the last 2 years, the wire that comes from the +ve side of the coil and disappears behind the heater airbox is indeed for the tacho (y)
ok cool, so do you know what the little wire from the -ve side is (yellow iirc)? I was thinking one is prob power for the tacho (from +ve) and the other could be the signal wire for the tacho (from the -ve). Not sure that would even work, never was good at how carb/dizzy/coil things work
It's been forever since I've looked at it but if it goes in the same direction as the one on the +ve side then it's for the tach as well, don't think there's anything else that connects to the coil other than the distributor of course....
ok so, new dizzy cap fitted and having not run for few weeks it was miles easier to start than it previously was.. I let it run a while and then decided to get this electronic ignition module fitted finally - all fitted and Char seems to be running really nice now, will have to wait and see if its improved cold start even more but it certainly is silky smooth running with all the new ignition parts compared to before. (y) The rotor arm does have a little pitting on and i'm slightly annoyed with myself for not just ordering one so i could replace at same time as cap but hey-ho, its no big deal to do that later on.
gotta say I am leaning towards leaving it as a 750 and not dropping modern engine etc in.. Time will tell though, I really want to change the wheels but can't make a decision on any lol. I might freshen up the suspension next while i ponder wheels.
Don't bin the wheels if you change them please! I'm sure you wouldn't, but just a reminder that they are 127 Palio ones, wonder who has one of those........ ;)
