slow rider
- Joined
- Nov 13, 2015
- Messages
- 25
- Points
- 15
So the weather is finally nicer today so I tried to get this job done.
I've managed to took apart most of the panels - however I could not remove the glove box and could not locate the motors.
I've removed the screws from the right and left - both the small ones and the large once under the door + on the sides and the one hiding inside that hole on the right. I still can't pull it out and I am not sure what is holding the box in.
Otherwise other panels were removed.
At this point I've took a good look at both right & left sides and I can't see any motors.
This is the view from the right (passenger) side, towards the center. Took from under the glove box I can't remove. You can see the band that limits the glove box door + Denso logo on the plastic housing in the middle where I thought I would see motors.
And this is the view from the left (driver) side... can't see any motors either?
Please help my car is in pieces right now.
