Seicento Another yellow Schumacher
So after getting my old sei where I wanted it and realising the I cant afford to insure it modified heres the build of my old sei
https://www.fiatforum.com/showthread.php?t=416521
I saw this nice looking schumacher on on ebay with no bids and a few hours left so I had a bid won it and now I've just picked it up and on the way back to Birmingham from London with it
What I didn't realise the car come with full service history up to when it was sat for two years and looks really rust free so I'm happy
  • Like
Reactions: varesecrazy
Nice pinto. As I said before I have never seen a 5 door with dealer abarth kit on the road. Pretty rare beast. If only ever seen pics online.
Loads of hgts about though.
Has it got the optional subwoofer in the boot? I fitted one to mine which was a nice upgrade which uses wasted space behind the c pillar.
No it hasn't got it fitted hasn't even got rear speakers it but I do have one audio is the next thing on the list for the punto and and it being so rare is the reason why I wanted to keep it in the family
Actually got around to starting a job on the sei been getting the punto ready for brooklands so haven't had a chance to get on the sei but anyway I've managed to pretty much get the rear discs conversation all kn just gotta sort the handbrake cables and brake pipes out oh and trim the Allen key heads off the stud kit so I can do the wheel up all the way but it's nearly engine time 1460922022411.jpg1460922034204.jpg1460922045764.jpg1460922057434.jpg1460922069474.jpg
Decided to make a start on getting the 1242 in over the weekend with the weather being warm so here's the weekends work one major problem that's engine mount t belt side as you will se from the pictures
Good start take the front end off I couldn't understand why most cento engine swaps have pictures off no front end now I definitely understand why lmfao
Loom and pipe work off
Old 52000mile 1108 out shame to not use it as it's a lovely engine but the head will stay in use on its red bigger brother
Now that's a problem but I'll sort it that reminds me I've gotta get the pollybush engine mount insert brought as I don't want to be spending £50 on a mount
As you can see all out from under the car
Old vs new
Alt and trigger wheel on going to be running it wthout a cover for a bit so I can check everything is okay tell I'll refit the bottom cover
Was going to chance it with the old and must I say mint oem clutch but I thought while it's out I'll change the clutch might do the cable and quadrant at some point aswell
Gearbox all bolted back up and ready to go in
And in admitted the gearbox mount is tight and I've still got to tighten up the rear gearbox mount and sort out the engine mount but it's nearly there have a jack holding the engine up in about the right place might be close or nearly there in the next few weeks then back onto the rear brakes
Nice work. I had exactly the same thing with that engine mount bracket and bolt. The threads were border-line so I tapped and reused it. Then on first shake down run it failed at 60mph and engine dropped down. No damage but the throttle cable was taught and the revs stayed high as it limped home. Wouldn't recommend it though
Cheers purf if that engine mount played ball it would have been bolted in and nearly ready to go
And was talking to my dad about the plate and bolt I quote "wouldn't worry about it I've sorted worse" so he's going to get that sorted for me
Didn't get much done today but got a new wheels though swapped tyres another scrap yard find but definitely a needed change for you now back to engine stuff oh and my polly insert come today
So had quite a good week on the cento getting stuff done through the week and finally having it running
First off I got hold of the right engine mount to fit my polly insert will be doing the rest when I can afford it 1464029154479.jpg
Then decided I'd find myself a set off gt3 style brakes of a Doblo van don't think there alloy like the gt3 callipers but the pad area between the gt2 calipers I had and these are alot bigger
My dad finished off the inlet manifold for me getting the map sensor in
Then Saturday I started to get it all bolted in and together and it decided to rain happens alot in Birmingham for some reason the cover I've had over the cento come in handy
Charcoal canister also removed and the Solinoid cable tied out the way still plugged in
Drive shafts in and engine bolted up sorry these are a little out of order bit you get the idea
Inlet mani on and had to make a gasket for the tb good old kelloges box
The first start up didn't got so well at first had the firing order well out and totally forgot I had another fire engined car sat over the road so open the punto bonnet copied the firing order and she fired straight up excuse the laugh in the video I got excited
[ame]https://youtu.be/w-0lEXVGDkE[/ame]
How it looked at the end of the day
Also decided to work out of the wheels would rub the answer was no had loads off room and don't need to roll the arches
Just got tho figure out the rest of the exhaust now and I've had a few ideas for the inlet side of thinks basically the same as the attached picture with my cda on the end instead of a cone filter
Well another week of doing bits and bobs after work
First my spi strutbrace come so start to get it fitted to abit off thinking and some cutting but to goes on lovely misses the abs pump ect 1465115322125.jpg
Swapped rear calipers with my dad so he had a direct bolt on rear disc conv for his mk2 punto so I've now got alfa 146 calipers
The sorted out handbrake cables and brake pipes
Just got to bleed brakes up and exhaust left to do
Nice! I have fitted a used janspeed back box recently and had to get some stainless adapters made up. Some wierd sizes needed huh
I'd like to say she's done bit she's far from it needs a few things sorting she's slightly lumpy and really sluggish low down untill about 4000rpm where she really comes alive so I'm going to check the timing brakes are absolutely **** atm so I'm going to give them another bleed I need to extend the rear lambda sensor and put it back in the exhaust as that could also been causing some hesitation I'm getting down low but hay that's project cars there never really going to be done 1465712914168.jpg1465712941205.jpg1465712953061.jpg
Waw such a great work what is your wheel setup? I read the post maybe i've miss something ;)
What ecu is running your p75 engine ?
