Technical 2005 Ducato alarm off
Uhhuu
Narva
Hello! I have 2005 Ducato 244 with 2.8 disel engine and I'd like to know how to turn alarm off. Can't be inside with locked doors. Read in manual, that there should be alarm off switch near fuse box, but mine seems not have it. Any toughts?
Just a thought, does alarm activate if you lock van manually with key rather than with fob/blipper, or can you activate lock from inside by button?
Maybe try locking van through drivers window in door lock with key, then see if alarm comes on when you turn ignition on to shut the window, bit of hassle but may be worth a try.
Try the lock button on the panel below gear shifter , it locks the doors without the alarm
