Hello everyone
I have a roblem that showed up lately on my gearbox
all the gears are working like charm except the fifth gear
once it's in it fits with no problem but when i accelerate it moves like half an inch out of it's place
when the pedal is pressed or released it moves , no other gear does that they are all working perfectly
i checked the oil level and it was ok,
I use the 5th gear most of the time as the car is mainly used on highways
can anyone tell where the problem is? can it be the gearbox linkage or the gearitself is worn?
I'm not expert with this but i read someplace that the fifth gear is the last gear and there is a nut holding all gears on their shaft inside the gearbox, and could it be the nut loose and needs tightening?
