Old 24-01-2013   #1
Unhappy Stiff changing into and down to second and jumpin out of 3rd gear occasionally
Ive got a 2007 1.2 8V Grande Punto my car is really stiff to change into 2nd and down to 2nd gear and occasionally jumping out of 3rd after putting it in gear anyone else had the same problem or is it just my driving? any help would be greatly appreciated as this is winding me up now i hope its nothing serious thanks .
jwalshy200 is offline Reply With Quote Quote
Old 25-01-2013   #2
Re: Stiff changing into and down to second and jumpin out of 3rd gear occasionally
I believe the gear change linkage is controlled by cables which are prone to siezing up.
I'm sure someone who knows the score will correct me if i'm wrong, or offer an alternative solution.
keat63 is offline Reply With Quote Quote
Old 25-01-2013   #3
varesecrazy has donated!
I've not got a GP YET.., but yes alot of the modern'ish FIAT's have cable gear linkege arrangements,
partially seized cables can make changing awkward,
and I suppose could also make it jump back out ( de-select itself) if there is sticky tension in the cable ( just engaged then the tension pulls it back out),
give it a lube and let us know what you find,
Charlie
(T) Mk2 Punto HGT Gear changing - Stiff!! dudds24 Punto (Mk2/2b) 22 12-03-2018 19:13
(T) Stiff gear changes heady69 Punto (Mk2/2b) 1 06-12-2012 22:34
(T) Gear stick moving in 3rd gear ?? bravotony Grande Punto 1 11-07-2011 14:23
(T) stiff gear changes Simon12 Panda 8 24-02-2011 02:24
(T) Stiff gear changes pookus Cinquecento / Seicento 7 15-03-2008 14:56
