Welcome.
Will add this for the peeps interested in the 3 gearboxes.
I have a
4 speed automatic gearboxes in my 2006 2.8 JTD.
It lubricates with an oil slinger design and sump. It basically just throws the oil everywhere inside and drips down via gravity.
My auto gearbox is made by ZF.
I read my gearbox manual when changing the ATF oil which i sourced elsewhere.
It doesn't come with the owners manual or was missing.
Apparently, the autos were less common compared to the manual gearbox models.
You probably can add a 5 gear auto gearbox as an option.
From 2006 and onwards, autos are more common with a robotic hybrid manual mode gearbox.
Sounds like exactly what i have almost. Like a prototype transition model in 2006.
However, I read the specs on the manual gearbox version....which to my understanding, always was a 5 speed? I could be wrong on the manual gearbox!
Actually, it will be in my Owners manual but i only glossed over that section as it didn't apply to me. But i had to eliminate the manual gearbox figures. Figures for manual and auto gearbox is in the manual in close proximity or on the same page.
I have wondered if people are getting the auto and manual details mixed up on the forums?
I have heard many people say the the 2006 didn't even come in an auto gearbox.
ie. My auto insurance company has the info wrong online with their database.
I have experienced massive confusion with parts companies, insurance companies, etc. because of the gearbox type and variants.
My van is good. But the devil is in the detail.
You could easily get the wrong oil, wrong oil levels by not taking into account auto or manual gearbox. The type of oil is probably different also. Both readings are in the manual....
The variants multiply the confusion exponentially.
Then there is the variants. Box, Combi, panorama, VAN, BUS, MAXI etc.
You have to read that owners manual like a lawyer.
That has been my experience...
I come from a technical background but I spent at least a full week getting all the info correct. Probably 3-4 weeks.
It didn't help that someone removed the model tag off my auto gearbox either.
So i had a "blackbox" gearbox where i had to identify the model.
This all flows into other settings such as Torque settings when fixing your VAN or MH.
I found eLearn not easy to use.
This may be a native language thing and translation from Italian causing this.
I had whole sections missing in eLearn for my VAN.
eg. What is the torque setting for the front axle hub nut on the MAXI with auto gearbox?
The front axles are different on the auto compared to the manual. Also the CV joint is different as a result.
Been reading about front bearings going on the Ducato. That seems to be the reputation.
But what happens if people are torqueing the hub nut up to wrong spec because the spec isn't in eLearn? I certainly couldn't find the specific torque for the hub nut for my vehicle in there.
I do wonder if this is happening with Gearbox oil? ......
So I revisited my owners manual....and there it is!
Different gearbox oil for manual and auto gearbox. Different volumes also.
I would be very wary in overfilling.
There are big warnings in the manual regarding not doing precisely that.
I have chosen to follow the manufacturer guidelines here.
I can only check via
MES using gearbox oil temp as my gearbox is sealed.
It is very difficult to check the oil level in mine. No dipstick or oil level window on my gearbox.
Well, that leaves you with plenty to think about!
