Fixing my Skyroof / Sunroof [reset]
Hi All,
I just got a cheap deal on a Stilo, its a 1.6 dynamic with all the extras, including a sunroof that doesnt work! Its has the arbarth kit including 17' alloys and in my opinion looks better than any ford or vauxhall!
Anyway i've seen some really good articles here so i thought i would report on them and let you know what happens.
The first thing i need to overcome is the fact that the sunroof does not open at all, neither does the blind, the previous owner seemed to think its the motor, but its an expensive mistake if its not so i will try everying else first!
Also i think the blind uses a different motor? (can anyone clarify?)
My plan is to first do the full initialization sequence, and hopefully this will clear up the problem, but i doubt it! (having previously owned a GTV and Punto, italians make good engines not electrics!)
second to manually open it and clean as per thread;
https://www.fiatforum.com/stilo/72111-cleaning-sky-roof.html
also while its open have a good look around for anything out of place
lastly either take it to a mechanic to do more tests on switch and motor(expensive) or fit new motor (more expensive).
I actually pick the car up this afternoon form MOT, and i have yet to try opening it with the remote.
Thats my plan, if anyone can make any other recomendations or pointers to look out for while trying to fix this it would be much apreciated!
and i will have to wait till it stops raining !!!!
DT
