General radio in 20 minutes mode...?
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
snowyyo
Ulster
hello guys, i have had to re-install the factory tape deck in my stilo for a while, but its coming up ' 20 minutes mode'. does anyone know how to get it working properly?:confused:
go into the menu & select ignition time OFF & radio will turn off when you turn ignition off.
Just checked in original Stilo radio, after ignition off radio is turn off, but when turn of radio without ignition in lcd stay: 20 minutes mode. How to turn off 20 mintes mode, e.g i want listen music 30 minutes :D
Epic thread revival....
Simple answer - turn the engine on.
I dont think the 20 minute mode can be adjusted for when the ignition is off - its designed to be a battery saving feature so that if you ever leave the radio on without ignition it'll cut off and not keep going till the battery goes flat.
