Technical back light problem
stilo 2001
Hi,I have a stilo from 2001 1.6l and the right backlight its not working properly. When I blink, the reverse light goes on and its blinking to, or when I break all the bulbs light up(break, blinker, rvers and normal light, but only on the right side. The left one works perfectly. When I break or blink or I use any light witch is on the right side it appears BULB FAILURE and witch bulb is failing.
Can someone help me please :(
mine had a similar issue check the connection its the white bit that plugs into the black bulb holder they melt. that was the issue with mine the guy bent some prongs inside the white bit and that fixed it. hope this helps sorry my terms are as clear as mud lol
i cleaned the plug and the connections but its not working. i tought it is the fuse panel or something, and then i read that supposedly it has a fese panel in the trunk but i could not find it.:bang:
Hi, Welcome to the FF.
There is a fuse box in the boot (trunk) behind the left side drop down storage compartment, but there are no fuses in it for the lights.
As there are several lights affected, but only on the right side, your problem could be caused by a poor right side multiple earth connection. The left side multiple earth connector is the black bolt on box shown next to the rear fuse box below, but there will be a similar connector on the right side of the car that could be causing the problem.
