hi there
I have tried searching and cant quite find a solution to my problem so was hopeing someone could help or give any advice on what to check ?
My problem started a couple of weeks ago where I changed my radiator pipes prior to doing this all was well and once changed took the car for a drive now I do not have any boost.
I noticed when the no boost fault issue started I seen smoke from from the exhaust which turned out to be a blown oil seal in the turbo which has now been replaced with a new turbo.
Now the new turbo has been fitted I still have no boost but the smoke has cleared.
I have changed the MAF sensor Air Filter and I can also hear the turbo spooling but it just isn't producing any boost at all just feels as tho its a normal diesel.
I did also try a manual boost controller and also linking the boost pipes incase it was the solenoid but the issue remains.
I have noticed tho if I rev it to 3k or just over 3k rpm I only generate 3 -5 PSI where previously I was running 22PSI and the turbo would come in at around 1200RPM
any help would be great
thank you
thank you
