Having just done my glowplugs on my JTD, I have a tip for anyone about to do the same...
USE OEM GLOWPLUGS!
Sounds obvious, but I originally bought a set of NGKs since they are supposedly good quality plugs and I wanted to make sure I had a decent set in so that I wouldn't have to replace them again for a long while.
First thing I did before I even installed them was to test one on a battery (just out of curiosity to compare them against the old plugs.) They were relatively slow to heat up, and I mean slow enough to get me concerned enough to go out to buy an OEM plug to compare them against. The OEM plugs are Bosch.
Connected in parallel to the same battery (as they would be in the car,) the OEM plug heated up substantially faster than the NGK! It also appeared to reach a higher temperature (by glowing more) and after disconnection, retained the heat for much longer. As well as that, the shaft between the head and thread of the plug is thicker on the OEM Bosch ones, meaning they are far less likely to break when you come to replace them!
Hope that helps someone in making the right choice The glowplugs on Shop4Parts are OEM and fairly reasonably priced.
USE OEM GLOWPLUGS!
