Thread Tools
Old 29-04-2007   #1
Portugal
poor mpg on fiat punto 1.2 8v,please help!
Hello everybody!
About 2 months ago I bought a third hand fiat punto 1.2 8v,with aproximately 100.000kms on the clock.And since then,I have been registering a very high fuel comsumption,really poor mpg!I have changed the air filter,plugs,spark plugs and even took it to a diagnostic machine to check for faulty sensors,but the ECU is found to be in great shape,no faulty sensors whatsoever.The mechanic tould me that it was burning all the fuel properly,there were no CO2 problems with the exaust meaning that theres really nothing wrong with O2 sensors.I also changed the clucth 2 days ago,but all in all,mpg remains the same.I drive like a very old granny,no town driving,just 80 kph on freeway,and going very easy on the throttle.tyre pressure is ok,but 175/70 are fitted,instead of the 155/60,can this be causing all the problmes?
Im registering an average of about 9litres per 100 kms,not normal.
And the car seems to be pulling fine,no trouble at all.
A friend told me I could have a ruptured exhaust,or fuel line,but theres no smell not even noise.
Please excuse my english,Im from portugal!
hope someone can help me.
many thanks!
p.s.:altough having this problem(and some others),I just love my punto
Srgio de Faria e Silva is offline Reply With Quote Quote
Old 01-05-2007   #2
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
Re: poor mpg on fiat punto 1.2 8v,please help!
id recomend fitting a new thermostat.
i have the 1.8 punto hgt, and mine had real poor fuel economy, fitted a new thermostat yesterday, and its gone from doin 22mpg, to 28mpg, what a difference from a 20 thermostat.
very easy to install, on your engine its on the righ hand side of the cylinder head...
try shopforparts.co.uk for a good price on one.
you should be able to tell if your thermostat is a bit dodgy, it may take a while to get to half on the gauge, not stay at half, etc.
chers and hope it works for ya!
Thanks Robs thanked for this post
Likes Robs liked this post
matty seasider is offline Reply With Quote Quote
Old 01-05-2007   #3
fenton_jd has donated!
Mine has exactly the same problem, although my engine is totally shagged but it doesnt feel lacking in performance.
I cant find any leaks anywhere, Its doing my head in.
fenton_jd is offline Reply With Quote Quote
Old 02-05-2007   #4
Spain
Quote Originally Posted by Srgio de Faria e Silva View Post
Hello everybody!
many thanks!
Hola Sergio,
I have suffered a similar problem and I went almost crazy trying to identify what in hell was wrong (I have a Fiat Punto 75S 1995, 105000km). In my case the injectors warning light would turn on after some driving (no always though) so I was sure it was some fuel injection related issue. The car was also lacking power, it could not make it any faster than 140km/h.
One day I finally got the problems solved by doing these 3 things in that order:
1. I tested the compression which resulted to be really low, especially on two of the cylinders. I sorted this out by cleaning the pistons.
2. I change the ht leads.
3. I reset the ECU
Now the car can reach about 160km/h (it takes its time though) and uses the same amount of fuel described on its technical specifications (which by the way its still quite high for such an small car/engine).
I hope this helps.
Saludos desde Espaa :-)
/N
Likes puntonew liked this post
newstor is offline Reply With Quote Quote
Old 02-05-2007   #5
Punto.Power has donated!
As said above, replace your thermostat also i would change my lambda sensor and fuel filter, have you gave it an oil and oil filter change lately? Then after all of those have been done reset the ECU by disconnecting the battery over night, this should help the fuel consumption.
Punto.Power is offline Reply With Quote Quote
Old 04-05-2007   #6
Portugal
Hello again!
I would like to thank all of you who managed to find some time to reply to this!Im soon going to spend some more time trying to find the cause to all this,but still,my punto must be needing an oil change.I didnt knew that it would cause mpg issues,so,that will be on the top of my priority list to do on the damn car!(I just love it still...)
About the thermostat,I went to a parts store and looked at a thermostat,but I really cant figure out how it can cause any mpg issues as it has no sensors envolved whatsoever,its basically a mechanical part.About the pistons,Ill give it a try,but that doesnt seem to be the problem cause Ive manached to reach 170 km per hour for several miles!It pulls away nice as well,altough it seems that in low gears,it seems a bit sluggish...the fuel filter has been changed at aprox. 60.000kms,dont know if its necessary to replace that...
Once again,thank you all for your kindness!
(im just glad I have a cute little smart roadster when theres not that much money to spend on gas )
Old 10-05-2007   #7
have you chaned the HT leads, my 1.2 8v was really sluggish at low revs, i found it had 2 split HT leads, changed the leads and the plugs, an it goes better than it ever has.
philj69 is offline Reply With Quote Quote
Old 12-05-2007   #8
I assume that your brakes are not binding! Check to see if they are hot.
nch is offline Reply With Quote Quote
Old 13-02-2012   #9
Quote Originally Posted by matty_oakley View Post
Thank for the info as my punto's temp is never at half and always lower.so i will replace temp gauge.makes sense as when i got the car the temp was normally in the middle, thanks!
Robs is offline Reply With Quote Quote
Old 13-02-2012   #10
Trader Rating: 5
fingers99 has donated!
Replace thermostat, not temp guage. Id the thermostat is jammed open, or missing, the engine will run cold. The ECU will compensate by running rich -- effectivelt like driving with the choke on, all the time.
Binding brakes will make a terrific difference to fuel consumption.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 13-02-2012   #11
Quote Originally Posted by fingers99 View Post
sorry my bad i meant thermostat,yes i agree jammed open i think coz car takes age's to warm up.running at 38mpg
So im going to replace it.
Old 02-09-2015   #12
India
I have punto multijet 1.3, and its average is very low( 12 km/l). Egr and injector cleaned, but problem is still please suggest what to do,
Odo meter reading is , 61200
Raminder290191 is offline Reply With Quote Quote
Old 02-09-2015   #13
flisko's Avatar
flisko has donated!
only 12km/l, did you reset trip counter cuz they are inaccurate
flisko is offline Reply With Quote Quote
Old 02-09-2015   #14
India
I checked it by ful tank of fuel
Old 02-09-2015   #15
India
Only 480 km covered with 40 l
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 17:15
