Lamps by Post - For all your lighting needs
Thread Tools
Old 6 Days Ago   #1
South Africa
Cup holder removal
Hi guys! so at 107K km I've needed to do a rear brake job , rebonded shoes, light skim of the drums , new seals in the slaves etc.
Come to adjusting the cable which I don't think has ever been done before and I can't get the sodding cup holder out - I've removed the 3 nuts but there's summat holding the bugger near the front end.
I don't want to force it and break anything, any ideas?
Ok! So I found that there's a nut directly under the handbrake lever , duly removed and we're sorted!!
somyunguy is offline Reply With Quote Quote
Old 5 Days Ago   #2
varesecrazy has donated!
Re: Cup holder removal
looks like you've done the job now,
reworking the old parts - I guess parts are too expensive to obtain new in your location..
sounds like you are in a perfect position to make a mini-GUIDE to this trim removal
Old 4 Days Ago   #3
The handbrake trim and cup holder has three screws. One in each cup holder and another under the hand brake lever. Take them out and lift off the centre cover. You can now adjust the handbrake cables.
A good way to test hand brake balance (apart form viewing the balance bar) is pull on the brake on to just biting and reverse the car. The wheel which turns needs it's cable tightening at the adjuster.
DaveMcT is offline Reply With Quote Quote
Thread Tools
(G) Cup holder inserts p111dom Panda 18 17-09-2016 11:08
(G) cup holder asbjch Punto (Mk2/2b) 11 24-04-2010 18:16
(G) Dashboard cup holder martbass Multipla 2 09-02-2009 08:53
(G) Cup holder - ideas? Tomasso Bravo / Brava 18 16-03-2007 17:41
(G) Cup holder device? Tomasso Marea 3 08-03-2007 15:29
