larkim
Established member
Replaced old pads this weekend (the first time I've done something "serious" on a car!) and the pads I used had shims attached to the rear (existing pads didn't).
I understand these are anti-squeal shims.
When applying copper grease to the rear of the pads, would you put the grease between the pad and shim or just on the rear of the shim (and the rear of the pad where visible)?
