We all know that the original Panda steering wheels are small and skinny. For those of us that use our Pandas every day, a Fiat Cinquecento Sporting wheel is easy to fit and improves comfort. Here's how to do it.
Firstly, disconnect the battery. If you don't mind disturbing the neighbours due to the horn constantly blowing then leave the battery connected.
Next, ensure the steering wheel is dead centre with the wheels straight ahead, this makes life simpler later on.
Next, prise off the horn push in the centre of the wheel. I found this was easily done using two small flat blade screwdrivers, it just pops out.
Once removed you can see the 24mm nut holding the wheel in place, the springs which operate the horn and the washer below the nut. Remove the springs and set them aside.
Next, get a 24mm spanner or socket and loosen the nut carefully. It may be tight, but it will loosen. Be careful not to round the edges. Once off set it with the springs and then remove the washer. Don't lose them!
Then simply pull the wheel towards you, it will come away from the steering column easily.
Fitting the new Steering Wheel
Now, get the replacement steering wheel and slide it onto the steering column, ensure it is positioned properly, straight ahead in the same position as the old one was before it was removed.
Now place the washer, hand tighten the 24mm nut and replace the springs.
Once you're happy with the position of the wheel tighten the nut using your 24mm spanner or socket.
Before fitting the horn push reconnect the battery and take the car for a test drive to ensure that the steering wheel is correctly positioned. If may need adjusted to get it dead centre.
Once happy refit the horn push and you're done.
Don't throw the old wheel away! It's nice to be able to return the car to original trim.
