fiat bravo 1.6 16v 2000 runs fine when cold, tickover drops to normal when warmed up, when i press the accelerator there is a flat spot then it revs ok, however, the revs still fluctuate between 1200 and 800 and engine dies at junctions
so far i have changed.....throttle body (mk2 with the sensors built in) inlet sensor, crank sensor and lamda sensor, i've reset the ecu, there are NO warning lights, i've run out of ideas :bang: it's still the same it was serviced 2 months ago, had new injectors 6 months ago and i don't think i want it anymore, as nice as the car is, i really don't think i can be bothered to spend any more on it.......unless anyone has any more ideas that i can implement with minimal cost, it will be appearing in the classifieds
