I have just bought a 1984 x 1/9 vs off ebay and there are a few niggling problems that I thought you may be able to help me with. Here goes.
*Carb - On trying to start the car for the first time yesterday I pulled out the choke noticing it was very stiff on operation. On removing the air filter assembly I noticed that the cable was the frayed mess and the actual actuating mechanism is broken off the carb. It looks like the plastic part snapped some time ago and there seem to be parts missing. The engine did not start unless fuel was sprayed into the carb, and then only for a few seconds. Am I correct in thinking that this would be normal for the car to not run when cold with the choke off or could there be other carb faults?
How available are parts for these weber carbs and what other vehicles were they used in? Hopefully you will say that they are the same as the uno as there are loads of rusty ones in my local scrappy!
*Electrics - The last owner put a blooming alarm system in, and its very annoying. I'm not looking forward to sorting that out so it works the central locking when the button is pressed, maybe I will just take it out. Anyhoo, the real problem is the electric windows. They dont work. My knowledge of electrics is limited, I have a multimeter but am only capable of checking voltage, dont really understand all that resistance lark as yet, but feel free to enlighten me. I checked voltage across the window switch and it showed around 1.5v. There are 6 connectors, 3 for the up and 3 for the down. What should I be testing for? Could it be a bad earth? Is having windows that dont work an mot failure? (for some reason the last owner fitted a manual handle to the driver side)
*Brakes - The front brakes on the car are stuck on slightly, the car can be moved but much force is needed (4ppl). I have taken the caliper off and popped out the piston. It needed quite alot of foot pressure on the brake pedal to get the piston out, so I was expecting a rusty old thing. but the piston looks smooth and shiney. I will give the piston a good polish and grease the sliders. If the brakes still stick after this what problems could there be.. master cylinder?? The disks are in good nick, as are the pads.
*Blinkers - The indicators seem pretty slow in operation at around one blink a second. However they blink fine when operating the alarm..any ideas?
Thats all, well apart from the rust! Hey I cant moan for 150 quid can i!
regards,
Tris.
regards,
Tris.
