Windows 8 pre-beta release free and legal download
slugworth1987
The Ratter
St Austell, Cornwall
for any PC nerds that like to play with new software early here we are a link to a free legal download
http://msdn.microsoft.com/en-us/windows/apps/br229516
installs via usb as its a bootable iso
min specs are on the site to but basicly
1ghz CPU
1GB RAM
20GB HDD for x64
touch screen needs multi touch touchscreen interface and must be 1024x768 res
I've been playing with an older version of windows 8. It's defo worth using it at a res of 1024x768 min, you miss loads of menu options and features in anything lower.
Single touch works for menu and gestures, overall the touch interface takes some getting used to.
http://www.ehow.com/list_7408579_dell-c840-latitude-specifications.html << my college notebook running windows 7 Ult 32bit. has the 1.8ghz P4 LOL oh and WIFI (B,G)
my netbook runs at 1024x600 though running intel atom 1.6ghz with 2GB ram on windows 7 starter
i was going to install windows 8 to my notebook but its such an old machine i doubt the geforce go 440 would run it its the only short full on an amazing laptop
The version of 8 beta I had, I simply clicked through the menu to just install it as quickly as possible (had to do 5 in work very quickly) it kept the windows 7 and android installs. I didn't select any disk options just clicked on install it warned me a previous version of windows existed and that it would be saved but not functional in c:\windows_old it lied it still works LOL :)
i wanner try it but really can not be bothered making a partition etc
plus im running out of space, need to get a bigger hard drive but not at current prices
Has anyone set it up a dual boot with 7/Vista the main OS and 8 on a partition?
Ive been trying for a while and Windows 8 just wants to remove 7 from my C:\ drive and fresh install :bang:
I don't bother with multi boot. I have an ATA caddy and change hard drives when another operating system is prefered. Two 1TB mirrored HDs store most of the other stuff. +, If any thing happens and the system won't boot I just change the disc. :)
I can't make a disc keeps failing, here is log...
Windows Vista 6.0
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 9.0.9.100
Internal Version: 9, 0, 9, 100
Recorder: <Optiarc DVD RW AD-7170S> Version: 1.00 - HA 1 TA 0 - 9.0.9.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <Optiarc DVD RW AD-7170S >Version: 1.00 - HA 1 TA 0 - 9.0.9.100
=== Scsi-Device-Map ===
: ST3500630AS 3.AA nvstor64 Port 2 ID 0 DMA: Off
: Optiarc DVD RW AD-7170S 1.00 nvstor64 Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
Optiarc DVD RW AD-7170S G: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2096064kB)
Free physical memory: 956MB (979528kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.4.2012
Burn DVD Image
11:26:10 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
11:26:11 #2 Text 0 File Burncd.cpp, Line 3563
Turn on Disc-At-Once, using DVD media
11:26:11 #3 Text 0 File DlgWaitCD.cpp, Line 312
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1749856 (388:51.31, 3417MB)
11:26:11 #4 Text 0 File DlgWaitCD.cpp, Line 324
Write in overburning mode: NO (enabled: CD)
11:26:11 #5 Text 0 File DlgWaitCD.cpp, Line 2951
Recorder: Optiarc DVD RW AD-7170S, Media type: DVD-R
Disc Manufacturer ID: <CMC MA> <G. AM3>
Disc Application Code: 64, Disc Physical Code: 193
11:26:11 #6 Text 0 File DlgWaitCD.cpp, Line 499
>>> Protocol of DlgWaitCD activities: <<<
11:26:11 #7 Text 0 File ThreadedTransferInterface.cpp, Line 756
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 1749857 (1749857) = #1749857/388:51.32
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1749857 blocks [G: Optiarc DVD RW AD-7170S]
11:26:11 #8 Text 0 File ThreadedTransferInterface.cpp, Line 958
Prepare [G: Optiarc DVD RW AD-7170S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3583707136, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1749857 | 1749857 | 0x00
1749857 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
11:26:11 #9 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
11:26:11 #10 Text 0 File Burncd.cpp, Line 4362
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
11:26:11 #11 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
11:26:11 #12 Text 0 File Burncd.cpp, Line 4484
Cache writing successful.
11:26:11 #13 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
11:26:11 #14 Phase 28 File dlgbrnst.cpp, Line 1767
Speed measurement started
11:26:11 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2675
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
11:26:11 #16 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 590400
11:27:51 #17 Text 0 File WriterStatus.cpp, Line 245
<G: Optiarc DVD RW AD-7170S> start writing Lead-Out at LBA 1749857 (1AB361h), length 0 blocks
11:27:51 #18 Phase 29 File dlgbrnst.cpp, Line 1716
Speed measurement completed: 25.5x (35,194 KB/s)
11:27:51 #19 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 16x (22,160 KB/s)
11:27:51 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2675
11:27:51 #21 Text 0 File DVDR.cpp, Line 3259
Recording mode: Sequential Recording Mode
11:27:51 #22 Text 0 File DVDR.cpp, Line 3413
Start write address at LBA 0
DVD high compatibility mode: Yes
11:27:51 #23 Text 0 File Cdrdrv.cpp, Line 10187
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 26127F h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 2FE10 h
Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 84 0D 12 98 99 90 00 ....R.........
03 43 4D 43 20 4D 41 00 - 04 47 2E 20 41 4D 33 00 .CMC.MA..G..AM3.
05 88 80 00 00 00 02 00 - 06 09 0D 14 98 88 90 00 ................
07 88 80 00 00 00 00 00 - 08 07 17 0A 0E 09 04 00 ................
09 95 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................
0B 06 17 15 B8 99 85 00 - 0C B8 9A 32 03 20 32 00 ...........2..2.
0D 00 00 D0 00 00 00 00 - 0E 09 1F 39 2F 25 1C 00 ...........9/%..
0F 50 19 29 19 89 B5 00 - 10 88 84 00 04 00 04 00 .P.)............
11 00 00 00 00 00 00 00 - 12 09 2B 37 2D 29 1B 00 ..........+7-)..
13 50 1D 2D 1F A6 B5 00 - 14 88 80 00 00 00 00 00 .P.-............
15 00 00 00 00 00 00 00 - 16 0B 45 3D 3B 1F 25 00 ..........E=;.%.
17 30 25 31 0D 8A B5 00 - 18 88 80 00 00 00 00 00 .0%1............
19 00 00 00 00 00 00 00 - 1A 0C 51 51 51 45 2D 00 ..........QQQE-.
1B 90 23 2D 19 79 B5 00 - 1C 88 80 00 00 00 00 00 ..#-.y..........
11:27:51 #24 Text 0 File DVDR.cpp, Line 3551
Reserved Track size: 1749872 (1AB370h, 3417MB) -> return code 0
11:27:51 #25 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
11:27:52 #26 Text 0 File Cdrdrv.cpp, Line 1411
11:27:52.373 - G: Optiarc DVD RW AD-7170S : Queue again later
11:28:03 #27 SPTI -1106 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x0ac60040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
11:28:03 #28 CDR -1106 File Writer.cpp, Line 306
Power calibration error
11:28:06 #29 Text 0 File DVDR.cpp, Line 3819
EndDAO: Last written address was -1 (FFFFFFFFh)
11:28:06 #30 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
11:28:07 #31 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 16x (22,160 KB/s)
11:28:07 #32 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
11:28:11 #33 Text 0 File Cdrdrv.cpp, Line 11444
DriveLocker: UnLockVolume completed
11:28:11 #34 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
i'll pop to poundland for a cleaning disc and get a named brand dvd from some where later then.
i think have high power psu i think it was 750w cant find my build thread
edit found it i have 650w
Gigabyte GA M61P-S3, NF6100, S AM2, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, ATX
1 LN11596 2GB (2x1GB) CorsairTwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 5-5-5-12 ( now upgraded think i have 4 gig)
1 LN15182 AMD AM2 Athlon 64 4200+ Dual Core 2.2GHz, 2x 512KB Cache, Retail Energy Efficient
1 LN17485 Optiarc (Sony/NEC) AD-7170S-0S 18:LOL:VD±R, 8x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, SATA, Silver, OEM
