Technical Will parts from others fit my Mk1 1.6 Punto Sporting?
Cal03
got a 1996 MK1 Fiat Punto 1.6 Sporting however unfortunately I had a little accident. So I'm wondering if the following parts from other Punto's will fit:
Radiator
Drivers Side front wing
Front Bonnet
Headlights
Im not sure what it is called but pretty much the front part of the frame, if necessary would be prepared to slice off a current one then weld to mine,
Black if possible except for parts such as headlights and radiator,
Yes, the rad you'll need a GT one as far as I remember but the rest are interchangeable.
Ok thanks for that, apologies for making that my first post without an introduction or anything was just in a bit of a hurry to get back on the road,
you`ll have the dual reflector/bulb headlights with height adjustment on the 1.6 Sporting.
You should be able to make out the inner bulb & reflector on this pic...
