I nearly died on Dartmoor last night - came round a corner sideways and there was a quarry lorry coming the other way - had to bail onto the grass, heading towards a load of sheep - think i hit one, but didnt do any damage - scared me ****less!!!
The sheep was ok! I wasnt going too fast - just the sidewaysness screwed me! Car is fine too - lucky boy! At this bit its just a normal 60 zone - and I dont think theres many walkers around at 10pm - shocked to find an arctic at that time!
We've all done daft things (I have) but it's a great relief when no harm is done and you're able to put down to experienceThe sheep was ok! I wasnt going too fast - just the sidewaysness screwed me! Car is fine too - lucky boy! At this bit its just a normal 60 zone - and I dont think theres many walkers around at 10pm - shocked to find an arctic at that time!
Try http://shop1.actinicexpress.co.uk/s...s&ActinicSID=8b7efb1712abae184ea54422265b05bc
I have the Stebel Nautilus Horn on my Stilo - took 15 mins to fit and fits nicely where the original was.
Rather like the idea of this one. Is it a straight swap for the original horn in terms of bolting on and electrical connection, or are some modifications required?
You have to wire it directly to the battery and then put a relay in... Its all provided and is fairly simple to do!
It bolts on using the same hole of the original, and the 2 pin connector just needs cutting and 2x female connectors fitted in its place - all this is possible by taking the RH lower grille out. On mine the positive is pink, other is obviously earth.
Excuse the dumb question, but how easy is it to remove the lower grille? Does it just pull out, or are there fixings (to break!)?
Use something with a rounded edge so not to damage anything and gently pry at the top of the grille working round - the bottom is a bit fiddily, but just be patient.
Thanx Fiattech. Fitted a Stebel Nautilus today and am well pleased. Only slight concern is that using the original bracket meant the horn trumpets are pointing backwards towards the wheelarch liner which is vented and may let in road spray which will go straight into the horn! Couldn't mount it in the way indicated in the instructions. Did you find the same?
Yeah, it points to the rear but its not upward so not that much road spray will get in - had a look today at it whilst it was in the air for something else and there was not much in the way of anything around it - test of time will see though as i said before for under £30 its got excellent grin factor:devil:
You could always get one of those filter chargers K&N use to make their filters water proof ..and come to think of it that would be of better use covering your horn than their crappy filters
