General Wheels
General Wheels
TheJamie999
Bertha!
Doncaster, UK
Do wheels from any other cars fit on the Bravo? I've got the 16" wheels and was wondering if the Bravo size wheels match with any others?
The centre bore and wheel stud pattern is the same as many Alfa's and Fiats. 58.1mm 4x98
Depending on the size of the alloy they should fit no problem. Though be sure to remember there's more to think of than that. Firstly the wheel has to clear the crack callipers, width is sometimes an issue get a wheel that's too wide you could end up with rubbing alternatively if you get a thinner wheel you can lose traction etc. any specific wheels you were looking at?
If your willing to use wobble bolts it widens your variety by quite a lot. They give you that extra few mm so you can run 4x100 alloys. I used 4x100 alloys with wobble bolts for a year with no issues at all.
Just be sure to use spigot rings.
Hope this helps ?
These were 4x100
Just thought I'd throw this in here. AEZ got a bunch of wheels fitting the Bravo II:
http://www.aez-wheels.com/EN/
Click Products, then Configurator
Attached: what I ordered
