Intelligent Battery Monitor.
From Fiat: Avoid being stranded with a dead battery. Intelligent Battery Sensor (IBS) monitors your battery and automatically shuts off less-critical electrical systems to conserve battery
power while alerting you with an icon in your instrument display.
In practice it's also responsible for the alternator charge profile and S/S parameters.
Have you tried disconnecting the quick connector post (not the IBS) and just reconnecting after a few seconds? That should kill S/S but it may come back after a while.
Is it generally acknowledged that fitting this battery cases SS to disable, or is it just on your car? What battery is it exactly? I tried Googling but nothing came up.Fit a LiFe battery S/S doesn't like my 14.4Ah LiFe. A smaller than normal lead acid battery should also work.
Thanks. I've not tried that. Where would I find that connector? There's nothing immediately obvious under the bonnet.
I made my own:Is it generally acknowledged that fitting this battery cases SS to disable, or is it just on your car? What battery is it exactly? I tried Googling but nothing came up.
I made my own:
Very I just keep forgetting to press the button and realise the scary way when hillhold doesn't work and I start rolling!Depends on how badly you want S/S gone I guess.
I'll try disconnecting the connector trick (but it does seem unlikely that that would disable it).If I get S/S working, I'll probably be able to tell you how to disble it too
With the battery I'm guessing we could run with one that's about 1/2 the capacity of the OEM one needed for S/S
The weight saving with that will probably save more fuel than the S/S in my case
Disconnect the VE+ then IBS connector, leave for 30 seconds, and reconnect, IBS first.
Unfortunately my car is too old to benefit from the update.Of course, you could also get the update that remembers the last S/S setting (this is a good idea anyway as it's possible S/S might come back after a month or two using this method).
There's a red clip that lets you disconnect the VE+ lead from the battery without tools.
Logic would seem to suggest you should disconnect the IBS first and reconnect last in order to fool the system - surely disconnecting it AFTER removing the power cable would have no impact?
Anyway, I will test that of course. But where is the IBS connector? What am I looking for?
In a way I'm new to all this battery stuff, meaning, whilst I'm an ol' fart, whenever I have bought batteries in the past I usually get a "good" brand as opposed to a "budget" type and I usually get reasonable service. In a lot of cases we sell the car with the original OEM battery still going strong.Don't go crazy The OE non S/S battery is 60Ah from memory, while the S/S is only 63Ah.
On a daily driven car used mostly during daytime, 30-40Ah should be safe. Most of the over sizing of LA batteries is for cold weather starting, LA batteries don't like being cold, but we don't really have that worry.
Now I believe the battery in the TA and perhaps other engined S/S cars as well, is a different much higher spec to those without S/S. Is this so ??
If "yes" then in my case where S/S is going to be retired permanently, there is no need to get the higher spec battery.
Would that be a fair and reasonable conclusion or are there other things that rely on the better battery ?
.................AGM battery...............
