Yeah it' possible to change it for an aftermarket sub or amp, basically u have to cut of the factory connection and have all the wires showing then fit one of these, this connects to all the speaker outputs and also needs a ground which is there aswell..
http://www.caraudiodirect.co.uk/celsus-lc2-adjustable-converter.html
Now u have RCA output.
Then while ur there use the 12v wire for the remote cable input on the amp.
Then amp ground cable to errrrmm...seat latch which is bare metal. Then run the power cable through the firewall grommet behind the scuttle panel to the battery
Hope that helped
