- Joined
- Aug 2, 2021
- Messages
- 240
- Points
- 119
Where do I lift the front end up with a trolley jack? I didn't find anything in the handbook but then I hardly read it!
Good link. This car has had someone lift it on the folds under the sills and as a result opened up a join.Good post with pictures here: https://www.fiatforum.com/500/283597-500-jacking-lifting-axle-stand-positioning.html?p=2872165
I need to be able to lift the whole car front in one go and need to know what best place to do it.
Under no circumstances try to lift the rear on the twist beam
Some of us here remove the wheels and take them separately at tyre change time.
The post linked to above shows both front and rear reinforced sections of the body suitable for jacking the car. Here's the rear:If I am jacking up the rear one side at a time what is your suggestion for where the trolley jack goes for that. I can use two trolleys at the same time if I know where to set them.
Oh dear too late.
First time I jacked up each side as I wanted to get off the wheels but the second time I lifted it on the cross beam which is what I think you mean by the twist beam just enough to get ramps under it.
TBH I looked in the handbook to find where or how to do it and found nothing.
It would be my intention to take just the wheels if and when I get new tyres.
Yes the rear axle when new had a label on it. "Not to be uses for jacking" or words to that effect.
my axle has been historically bent. Still drives okay.
the rear only has the pads for a garage lift.
Which is no good you want to use axle stands, as there nowhere left to safely jack the car.
I am naughty, so can't recommend it for yourself. But I jack under the axle near the spring pan so I can use the proper pad for the axle stand and do one side at a time. Your only lifting half the rear weight, which isnt much when the fuel tank is empty.
I jack under the axle near the spring pan so I can use the proper pad for the axle stand and do one side at a time. Your only lifting half the rear weight, which isn't much when the fuel tank is empty.
Now that begs the question, what does bent look like?:idea:
I ask because it had a distinct bow in the centre like a bridge over the Tyne before I even started on it. And it is no worse now.
I tend to use suspension parts that take the power of the suspension for jacking a lot. I would do much of what you do!!
I like the car because it doesn't have todays hissy sissy fitments like electric steering but this jacking is a bit too up to date for my liking as a DIYer.:devil:
my First two were dead flat. I assume they should all be flat.
my current it like a bridge
Even a half an inch or more of bend mine drives fine..
The Panda has electric power steering; the current needed to power it is considerable.
Problems with it are posted here quite frequently, but fortunately most can be resolved by changing the battery and/or ensuring all the earth connections are sound.
It wouldn't achieve anywhere near the fuel economy it does if it had hydraulic power steering.
Even a half an inch or more of bend mine drives fine. .
Measured ½"!
