Technical Tipo brake assist fault
pippy1969
Bristol
I have a 2019 Tipo 1.4 easy that is showing a brake assist fault , occasionally showing up as ‘brake assist temporarily blinded’ issue.
Taken a look at the sensor in the lower front grill and found that it is clean but does move about a little. Is this a common issue? Assuming it should not move?
What is the easiest way to resolve?
I had an issue like this but it just said check brake control and the Odometer was flashing. Needed new sensor £1300
