Well, after a month with the car, I can say the following. It is lovely to drive when everything is working properly!! ;-)
Since I bought it(I knew I would need to do some bits), I have had the thermostat, Cam belt + bits, bonnet struts, clutch, front pads and discs, new front springs,Hazard light relay, and new wiper blades.
The clutch is slipping (intermittently this time) again which Roger (poweritalia) suspects is overboosting due to a fault. He didn't get much time to look at it today and it only did it once. He will connect a boost gauge on Friday and see if that is the problem. If not then the clutch is under warranty.
Possible that the idle control valve needs replacing and/or coil packs. Not 100% certain yet.
Turbo will probably need replacing in 12-14 months.
So my verdict?? Well........ I am hoping that once these issues are sorted, the car won't see Roger until it's service. I knew that buying a 10 year old italian sports car would be interesting, but I am still optimistic as it seems that most of the big jobs are now done. Wish me luck!
