Please help. Ive run out of ideas.
My wife noticed her key didn't unlock the doors. So we unlocked manually on the weekend. The car had power but wouldn't start (but there was no padlock symbol on the dash?) I changed the battery in.the fob and still nothing. So I disconnected the battery and reconnected it after 30mins which seemed to work and it fired up as if.nothing happened.
I then went to the shops when half way there, the dials went to zero, fuel light flashing, radio died, but the car drove normally and the heater was working. When we stopped the same symptoms as before with no central locking, key not starting the car. I tried disconnecting the bat again but it didn't work this time. Just as I was giving up it burst into life as if nothing was wong??
Got home, seemed fine then in.the.morning same again, no central locking, no start ect...
Did the battery trick, didn't work then out of the blue the fob started unlocking the car and all was fine again.. for a bit anyway. Now stuck with the same issues.and cant get it going.
Ive tried: new car battery, cleaning terminals, new.battery in key fob, earth to gearbox (using a jump lead) checked fuses, disconnecting and reconnecting the battery
Im out of ideas. Im thinking the ecu might have gone bad, it was a wet weekend
Please can anyone give me a.steer as.to what is going on or how to fix. Kind regards Lloyd
