I am not upset at all.
just the original question by the original poster is the car wandering what could be the problem be and now its getting messy and hard to follow and over complicated
I suggest a easy way to test for the rear bush. As this will vast majority.
Its not the only way. I am surprised someone hasn't suggested putting a lever between the subframe and the arm and wiggling. Which would be another way. But for some reason we have moved straight onto replacing the arm and then add other parts for good measure as well as discussing short cuts which in my opinion this is jumping the gun.
its nice to keep to the original post so when they read it back the replies are relevant
it could just as easy be inner track rods ends
https://www.fiatforum.com/threads/front-wheel-alignment.482598/post-4564173
It wasn't me that came up with the procedure but Fiat I just blindly follow it for the sake of an extra 30 second. The rear doughnut Bush is the easier of the two to torque up with the car on its wheels as the torque wrench is horizontal to ground so you can get a nice long sweep.
Its the same recommend procedure for lots of cars. Your closing the gap of the subframe and trapping the Bush top and bottom. depending on fit and angle you will be altering the torque required.to achieve this I will stick to doing the job as Fiat intended and yes I have seen both the rubber mounts torn out, incorrect ride height due to preloading of the bushes and suspension bolts that have come loose because the Bush won't seated correctly before it was torque up mainly when the parts were changed at a quick fit type garage (just can't the right staff).
"Please in future refrain from trying to correct me or pass judgement, polite request here, I've been twirling spanners probably before you were born so please no more judgements, as I say, polite request."
not sure what my age, your age or how long you have been twirling spanners has to do with anything. If someone younger or older pointed out I was doing something wrong I would listen. I have also done many things wrong I try not to make the same mistakes again, that's how I learn. I dont care how anyone else repairs their car. If I see something I think is wrong I will say so. You are free to correct me I will not take offence, I am often wrong.
