Gandalf500
Hi there
I'm attempting to replace a couple of spark plugs. But am finding it trickier than i thought it would be.
Main issue I'm finding is when I'm tightening the new spark plug, either the spark plug or the socket i'm using feels like it's getting stuck in the hole the plug goes into.
So I'll tighten the plug by hand as much as i could and then tighten a bit further with the socket. But then the socket will be stuck in the hole. I'll have to untighten it to get the socket out.
Below is the a pic of the plug i was working on. I got it in somewhat tight, at least i couldn't feel any play in the plug. Engine started okay and seemed to run okay. for the 30 seconds i had it on. Sounded okay as well.
I also noted when i untightened the old plug it would get loose and then get tight again. so not like a regular screw where it's smooth or the tightness gets progressively tighter, it would tighten up and loosen a bit.
Are spark plugs normally this awkward to replace?
I've ordered some copper anti seaze, as I've heard it helps stop the plug siezing and getting stuck.
I'm not confident in my replacement work, so looking for advice. As will try and do the second plug tomorrow maybe.
I also noticed the rubber cover on the air box is damaged and erroded. Can anyone let me know what that part is so i can replace.
And finally i noticed a rubber cover for some electrical wires is also damaged, and again I'd like to replace it, if anyone can let me know which part that is so i can buy a new one, that would be sweet.
