Picked her up Friday night and lover her
Work to do on her:
Remove hubcaps
Sand down and resprary originals, fit them.
Fit Veglia clock from the CLX and remove stuck on digital one from dash
Try and change HU over as it only has a Cassete radio, all be it a fancy one.
Fit speaker pods from the CLX into the hammock as the front speakers are fitted on brackets under the hammock.
Fit mud flaps.
Change rocker cover gasket as its spitting oil.
Exhaust sounds like its rattling so might be a loose or missing mount.
Check throttle as it feels stiff, might be the pedal or perhaps the TB needs some adjsuting
replace the nsr light lens as indicator is cracked and has a big bit missing, probably swap from CLX
Clean engine bay its its filthy
Back to black some of the trim and the interior.
Get wiring for spot lamps
Pics to follow
Work to do on her:
Remove hubcaps
Fit mud flaps.
Pics to follow
