Was after some advice... my 1.2 8v engine decided to bust a piston ring. I found a replacement engine on Ebay for £60.
Unfortunately my original engine has a cam sensor, the replacement does not. I have read that you cannot simply exchange rocker covers because of the reading marks on the cam. Also, l have heard that the engines have different manifold positions.
Is there a way around this? I'm guessing that I could pull the whole head off the broken engine and put it on the replacement?
Next point... Someone has said you CAN remove the engine block without removing the drivetrain - can it be unbolted, slipped off the rear of the assembley and lifted up and out?
Lastly... will the ecu have problems detecting the new engine? I heard that the electronics need resetting to match the new engine? I do have OBD software that will do this.
Any help will be much appreciated!
