Technical Rear windscreen coming loose?
ali94mh
Norfolk
Hello everyone!
I noticed an issue with my back windscreen yesterday where the bottom left of it (and top left slightly) is coming away from then frame/rattles when closing the boot.
Has anybody else had this issue and, if so, what did you do to fix this/get it fixed? Tried to contact Autoglass but they said they won't reseal the window to the frame unless I replace the entire windscreen (but the glass isn't damaged).
Many thanks
Hi welcome can you lift the glass away from the hatch surround(very slightly) are you saying? Has the car had a rear end crash?
Hi John,
Yes, exactly that! No accidents at all, just noticed it making a rattling noise as of yesterday & realised it can be lifted slightly away from the frame.
Best wishes
It's a tricky fix the bonded area is hidden from both sides inside and out, not heard of this before especially, if, it's factory original regardless of how old( our car is a 09 plate)
For a correct fix then yes the screen needs removing and re fitting
