Is lithium based molybdenum grease ok on the coupling ?
I am really hoping that the lock ring being moved does not put me in a hole :-(
I had put the ring in its place and tried fitting boot and retainer, should I put the ring into the boot first ?
Will the tabs slip into place ok ?
Just thinking back, does the boot butt up to the lip containing the slip ring or should the rubber lip go around that metal lip ?
I am presuming the flat tabs need to fit in the gaps in the outer ring where the red dot is and the protruding tab into the teeth of the inner ring of teeth
