Hey there guys n girls, I have a nice tricky problem for you. Tech stats - my car is a 1998 1.2 Punto S with an sx temp sensor and dash fitted so i have a temp gauge. Its done about 65k.
Yesterday (Tuesaday) when picking my girlfriend up from work, my engine started to over heat and the water started boiling out the top of the tank. The fan never kicked in. We let it cool down, gave it more water but it did the same and once again the fan didnt kick in so today me and my mate took the head off, changed the head gasket, changed the thermostat and re-built it up and tried it again. We first let the engine heat up to see if the fan would kick in but it didnt. We know the fan works because we tested it off the batt along with the cable so it isnt the fan. We also checked the fuses and there fine. We took it for a test drive and the temp went up pretty high again and the fan didnt kick in. Could this be a probly with the switch in the radiator? or maybe a problem in the loom?
P.S Obviously the radiator has been drained off water so it shouldn't be air in the system, should it?
Thanks for any/all replies.
Lozzy
Lozzy
