deafmazter
- Joined
- May 27, 2021
- Messages
- 55
- Points
- 70
Hey guys,
I'm facing the following problem. My car (punto hgt 1.8 16v 183a1000 with throttle cable, so not electronically controlled) jerks at spontaneous throttle and quick throttle release. Now I have already done the following:
1. Replaced all the bad engine mounts (2 out 3)
2. Replaced wishbones.
3 checked both the support arm and drive shafts for play. So they don't have these!
4. Filled all engine mounts with PU rubber, which unfortunately did not help. Shifting is better now because the car shakes less. But the "problem" is not solved.
5. Throttle cable adjusted and cleaned (maybe got stuck).
Other than that, I don't hear any strange noises. It is only with spontaneous throttle release and acceleration and shortly after that throttle release. Otherwise the car drives
