Erm... Excuse me, I was sold Char' as a unique one of a kind Panda, now you're just flaunting her style off to everyone else
Surely you don't expect me to keep coming up with new ideas?
The back axle and leaf springs were sand blasted, coated in zinc primer, then painted black. All the suspension components were given an extra coat of black paint as the one they come with when new doesn't last very long.
I had it on good authority that Skoda Felicia est. rear springs (pre 99) were the ones to use for raising the front suspension, but once fitted I found that they put the shock absorbers to their full extent. Once we had cut a couple of coils off however, they were fine. Good enough to tow Bucket to the NEC anyway, I've yet to drive him on the road as he's not been mot'd yet. Nor does he have an exhaust system.
The rear suspension has been raised using a custom 12mm spacer block between the axle and the leaf springs and bolted down using new high tensile bolts.
Brakes have been overhauled and painted, and now use goodridge hoses.
The fuel tank is a later inj. type from Germany fitted with an internal pump/sender unit to suit. This tank also has two holes for the breathers that are connected to the charcoal canister so I had to canibalise a plastic tank from a Panda clx to get the necessary valve/ connectors. I found these to be very difficult to remove from the plastic tank and cut them out in the end.
Now we all know how the 4x4 tanks rust, so rather than rely on the one coat of silver paint they come in I covered it with the same stone guard the underside of Bucket is protected with. Then once dry the tank was repainted silver over the top.
The tank wasn't a straightforward fit to the floorpan either. It sits too high and the inlet tube fouls on the chassis. To overcome the issues we spaced the tank down about 20mm and changed the angle that the filler neck exited the tank, making it point down a little more. The plastic filler pipe has a larger bore than the neck too so we had to use a double rubber ring to make up the difference, a piece of air filter inlet hose came in handy here.
Finally Bucket could be put back on his wheels and pushed out blinking into the daylight again......
