NebulaStilo
- Joined
- Jul 18, 2019
- Messages
- 220
- Points
- 50
Thanks Ralf and Wody.
I'm trying to get hold of someone who has a scanner. I want to invest in one.
I have the MAP sensor. No sensor on pipe Or throttle body. Only idle control sensor on throttle body.
The sensor i cleaned is on the engine side of the body. I tried looking for signs of a loose plug clip laying around that could be the MAF sensor plug but nothing.
I changed to a K&N cone filter that was laying here in my garage. Car sounds better and drives abit better. I took out LAMDA sensor connector and the car slowly dropped RPM like it was going to cut out and then I put it back and slowly came back up to idle.
Removed sensor after cat and no change.
As you see in the video,the car accelerates like that needle done in the video(when it dips in rpm)
Ive noticed when the air is like really chilly outside like at 2am coming from late night shift then the car runs better,if not,I'll say it runs like it use to. But thats only when its really cold
I am 1 of like 3 people in Cape Town with a Stilo. Other 2 has either jtd or 2.4. I'm only guy with 1.6 ?
