General Petrol tank vent
chase
bedford
Hi All,
Son borrowed my posh car leaving me with his '97 Mk 1 punto , naturally it needed fuel , when removing the fuel cap( after driving 10 miles to work ) there was a sucking in of air so presumably the tank vent is blocked .
Question , how is the tank vented ? and how easy to fix ?
Actually it sounds like its under a vacuum , e.g. fuel being drawn out the tank and not being repaced by air at atmospheric pressure .
This is quite normal the idea being as fuel vaporises in the tank you don't suck in clean air creating the perfect combustible mix
Also a breather pipe also has the potential to let fuel vapour escape into the atmosphere which is against eu emissions rules and regs
Normally the fuel vapour would fill the space but it's still sometimes leaves a bit of a vacuum
