Mr Gt Turbo
- Joined
- Oct 24, 2015
- Messages
- 3
- Points
- 1
Alright I'm looking for a guide to do the above conversion as my punto gt's tanks had it. Can any one point me in the right direction.
Hi , I had the same problem but managed to get the tank repaired, I have a spare plastic tank in case I need to do the same . I'm no mechanic but the tank should fit , the plastic tanks are slightly smaller volume and fit with a strap across the underneath where the gt one bolts through , all the pipe work is similar but you may need the filler neck too ,the ring that holds the fuel pump in is a screw on ring where the gt has a bolted down one , I have seen a gt for sale before with a plastic tank on it so I'm sure it's possible. I know the gt fuel pump runs at a higher pressure so I'm not sure if this would be an issue with the tank being plastic .
