Technical No air through heaters?
patterson11
Newcastle
the problem is that there is no air being blown through the heaters, this randomly stopped, also the lights behing the heater switches aree not on, so may this just be a fuse or would i be lookign at different problem?
could be 2 faults. turn your heaters to 4 and bang the heater motor with your hand if it air comes out its 2 faults if nothing happens then check your fuse
odd because the wiring in the foot well has nothing to do with the control lights just the motor itself ( im assuming you mean the heater resistor wiring)
