tonyramponi
- Joined
- Oct 28, 2012
- Messages
- 6
- Points
- 4
Hi all,
I've just purchased a 2008 Multijet sport Bravo. It's a lovely car but I have a number of questions. Tried searching the Forum for answers but got a bit confused since most of my searches pull up different Fiat models and not sure which answers apply to my Bravo.
1, What is the size of the sump plug key? Tried to change the oil yesterday but didn't have the correct hex bit. Is it 12mm?
2, One of the bulbs has blown in heater light controls. Before I start pulling things to pieces are there any guides for changing?
3, The top of my leather steering wheel has creased up and is peeling a bit, I notice that other people have had similar problems. Short of changing the steering wheel, are there any easy solutions for this?
4, I've had a 'check glow plugs' warning come up a couple of times but the car starts fine. Guess one of the plugs is going down and probably best to get whole set? Or could just be a loose connection?
5, Anybody know where there EOBD socket is? Have an error code reader so will have a go at using this to help debug item number 4 above.
6, Going to have a go at changing the cambelt, tensioners and water pump. I'm assuming the same 1.9 16v multijet engine is used elsewhere in the fiat range e.g. alfa 147, fiat punto. Could anyone point me in the direction of a guide which would also be applicable to my Bravo? Is it difficult to do? Changed cambelts on other cars and there seems to be a reasonable amount of access space. I used to have a Alfa 156 and chickened out changing the cambelt on that car since you needed cam locking tools. Are there any special tools required to change a multijet cambelt?
7, This is the first diesel I've owned, very impressed with it so far but it makes a bit of a rattle on start up from cold. Very smooth and refined when up to temperature. I know most diesels make more noise when cold but is this normal for this car? There is also a bit of a kick you turn the car over, Is this another Diesel feature?
Apologies for the rambling post. Having read back over it I may have been better off asking one question at a time over a couple of weeks
. If I get some helpful answers I'll add to the FAQ.
Cheers in advance,
Tony.
Cheers in advance,
Tony.
