General Name that part!
Derbyshire
I'm the lucky owner of a 2007 100HP.
After spending a few happy hours under the rear of the car trying to separate the back box from the centre pipe section, I came across this part lying on the ground underneath where I was working!!
Anybody know what it is and where it should be!
A big bullet :D :LOL:,you are lucky cuz you are still alive....Your Panda try to kill you ,gently.
Firstly, are you sure it came from your car? Could it have been there before you arrived? Just because you've just noticed it, doesn't mean it has just arrived.
It looks like a buffer. So, suspension, or exhaust.
Looking on ePER, the parts listing:
The exhaust does not appear to have any extra buffer, only the normal rubber hangers.
The suspension bumpstop in the centre of the spring does appear to have a pointy top. Check both sides for a comparison.
Other than that, crawl underneath with a torch and look for any hole with a clean edge, looking like it is missing something. Pay particular attention to anywhere where moving parts could touch, so near suspension and exhaust.
When you find its home, please post a new pic of it in place.
I'm almost certain it's nothing to do with the exhaust as that is all new now, fitted by ATS...new centre pipe and Ulter Sport back box.
I'll have a poke around the suspension later but fairly sure bump stops were complete and both sides the same.
I'm beginning to think that you may be right that it's nothing to do with the car at all!! :D
Rubbery..??
and around 19mm in diameter..
Strange. Suspension rubbers will be bigger diameter
Dous the flat end have signs of glue or rust..? Or even look torn / sheared off.
Rubbery..??
Yes, rubbery...flat end has a hole in it as if it should fit over a metal rod or something like a bleed nipple.
No sign of glue but there is a rust stained ring around the circumference.
And no sign of shearing or tearing...it's complete.
