Technical Mystery Wires
Hi there.
So I have had trouble with the parking sensors on my car and also the Aircon. I took a look at the battery under the bonnet and was amazed to find a loose plug just sitting there. I have attached a photo so you can have a look.
Does anyone know what it could be? Its the plug in the middle that is brown/purple/yellow.
It looks like the D97 connector used for options such as electric sun roof, electric steering lock, passive entry system (Easy Go), alarm system, Connect Nav+ navigation systen etc.
If it's supposed to be connected to anything, the other half will be under the fuse box.
You may find several other loose connectors distributed around the car. They are all likely to be for accessories and options that your car doesn't have.
