The Panda Nut
Nutty about Pandas Infected by Panda virus and OPD
⁶I need to do noops awful winter wheels. Only 4.8 years old and REALLY rusty
wonder what the price is now!I bought new steel rims for ours about 4 years ago, the old ones were terrible think they were only £100
Would appear £38 eachwonder what the price is now!
I added the rear camera … because I wanted to! It shows up on my screen so why not! Added a pic to give you ideas got a led reversing built thanks to john on here … and while your working your way through your list! Give your maff sensor a clean too (if you haven’t already) can get cleaner from eBay. Does help if you gently clean it every so oftenSo, as soon as the weather breaks, I have the following list of things to do before Festival Italia Brands Hatch
That'll keep me busy.
- Fit Horn. (Found a really loud on)
- Fit Bonnet horn trim.
- Fit door sill protectors.
- Fit Side Stripes.
- Fit reversing sensors.
- Fit reversing camera.
- Fit reversing lights.
- Fit DAB2 antenna.
- Fit TPS module.
- Define USB socket & other plug
- Fit Radio.
- Fit TFT Speedo.
- Fit rear Spoiler.
- Fit DRL bulbs.
But what have you peeps got planned?
That the new reversing light bulb?I added the rear camera … because I wanted to! It shows up on my screen so why not! Added a pic to give you ideas got a led reversing built thanks to john on here … and while your working your way through your list! Give your maff sensor a clean too (if you haven’t already) can get cleaner from eBay. Does help if you gently clean it every so often
Yeah good ain’t itThat the new reversing light bulb?
Not actually tried ours at nightYeah good ain’t it
I have it’s like a light sabre piercing the darknessNot actually tried ours at night
Where is it, I can't see anything from that photo? and I take it the LED is in the original light cluster?I added the rear camera …
No aftermarket clusters .. they on eBay too! The little camera is on the lower middle … better view of the road! I messed up first time…. That was a costly mistakeWhere is it, I can't see anything from that photo? and I take it the LED is in the original light cluster?
MAP sensor cleaning taken on board
I'll add TA filter to the list as well, might as well add th eoil change in too, it's getting close to time.
Jeezz.. you got me looking at wheels now
Ah, thx, thats an interesting spot. I might while I'm fitting the head unit, plug the camera in to get a idea of how it looks. Ideally my gut tells me the boot catch assembly would be the best place, but I don't want to mess with the boot wiring in the rubber gaiter.The little camera is on the lower middle
I had it dead centre then added aftermarket sensors… those other kind that look crap! It looked weird … ended up buying another bumper then a re spray yes look before you fit … higher up looked weird to me but it may suit you better!Ah, thx, thats an interesting spot. I might while I'm fitting the head unit, plug the camera in to get a idea of how it looks. Ideally my gut tells me the boot catch assembly woild be the best place, but I don't want to mess with the boot wiring in the rubber gaiter.
Where did you put it first time?
Ah, perfect.
The reversing bulb is a 144 led replacement bulb, that can be used in any clusterWhere is it, I can't see anything from that photo? and I take it the LED is in the original light cluster?
Gives you an idea of the view where my camera is … although it’s wet today!Ah, thx, thats an interesting spot. I might while I'm fitting the head unit, plug the camera in to get a idea of how it looks. Ideally my gut tells me the boot catch assembly would be the best place, but I don't want to mess with the boot wiring in the rubber gaiter.
Ah, perfect.
