Progress Today...
- Front exhaust on
- Gear linkage cable bracket and cables installed
- Clutch slave cylinder installed
- Gear box oil leak?
Front exhaust on: Described in previous post.
Gear linkage cable bracket and cables installed: Just when you think you're on the home straight you get bitten on the a**. I struggled with installing the cable bracket until I realised how to reinstall it. When I disconnected the cable bracket originally, I removed the small gear cable pivot/tube from the bracket first to improve access to the 3 bolts securing the bracket to the gearbox. So on reinstallation, plan A was to reverse the removal process: so I installed the 3 bracket bolts first, then tried to install the small gear cable pivot/tube. Result: couldn't do it. Once I'd installed the bracket onto the gearbox, I found it impossible to mount the pivot/tube back into the cable bracket because it's such a tight fit into the bracket, and there is no room for manoeuvre. The 2 seals on the end of the tube kept dropping off as well. Very frustrating.
So plan B, which is how I did it, is to fully install the pivot/tube into the bracket first, including the long central bolt, tightened to spec. Then I installed the cable bracket on the gearbox. All 3 bracket bolts are accessible, however, access to the top left bolt is restricted by the pivot/tube. Access to the other 2 bolts is no problem. To tighten the top left bolt, I started by screwing it in by hand as far as I could, then used a 13mm ring spanner which, due to the restricted access, can only be turned through 1/6 turn at a time. When the bolt is all the way in, I found it just possible to get a 3/8" drive socket and torque wrench on it. I think a 13mm ratchet ring spanner would be ideal for this bolt, and a small diameter 13mm socket.
I then jumped into the car and tested gear selection. No problem with selection of gears 1 to 5, but Reverse was a bit crunchy. See if things improve once I've got a running engine.
Incidently, I was able to reattach the gear cable end sockets onto the gear lever balls by hand, without needing any tools. They went on quite easily by hand. Before I did that I removed the rust and muck from the balls with a plastic scouring pad.
Clutch slave cylinder installed: 2 x 13mm bolts. No problem. The piston obligingly pushed in no problem when I pushed it against the end of the clutch lever to line up the slave cylinder with the 2 mounting holes in the bellhousing/gearbox. I then jumped into the car to test the NEW! clutch operation. Pushed the pedal down and it feels... light, smooth and silent! Quite a contrast to when the clutch broke 6 months ago. Also when the clutch broke it felt and sounded like the master cylinder was scr*wed as well. Tonight's demo showed me that the master cylinder is probably OK. I had forgotten my digicam so couldn't see/record the clutch slave cylinder/clutch lever working, maybe try it tomorrow.
Gear box oil leak?: While I was doing the above, a noticed oil dripping from the bottom of the bellhousing. Colour (clear) and smell told me it was gearbox oil, not engine oil. A relief that it's not engine oil, because that could've meant that the (new) crankshaft rear oil seal was leaking. So the other possibilities are: a) The OS driveshaft oil seal (new), b) the gearbox input shaft oil seal (new), or... c) maybe I overfilled the gearbox/diff? The drips are closest to the OS driveshaft oil seal - directly underneath - so that's my guess, or I overfilled. The owners handbook states the gb/diff capacity as 1.98L as I posted previously, but I drained out only 1.75L of old gearbox oil in total, and refilled with just short of 2L (new). By the time I'd finished working on the car Today, the leak had stopped. Will have to investigate. If it's the OS driveshaft oil seal at least I can get to the seal w/o removing the gearbox again, and I do have a spare seal. Hope it'll get through the MOT.
Think that's the worst of the reinstallation over with. The remainder tomorrow is all straightforward - the battery stand I have tackled before so shouldn't be a problem.
Mark
