thanks for the input-
the 899 turbo route-to be honest,im concerned that the torque will end up causing me transmission problems and the 2 899s i have owned have been the most unreliable engines i have had any experience with....Also,i have a van aaken low comp bottom end and t15 turbo that keeps looking at me in the garage but im thinking about other alternatives first.
the rotary engine route-i have already been there(allbeit with a different car).I had a 12a wankel engine and transmission that i was grafting into an old bedford rascal(told you i was a nutter).it was about the only front engine rwd engine that would fit under the front seats!I had the opertunity to use a bike engine but was going to fit the rear out with a rather large(and heavy) stereo system so it would have been totally gutless at lower rpm...
forgetting the issues of getting the head to fit for a moment,providing the bottom end is stable under high rpm the peak torque produced is substantially less than a high boost turbo and comes in 'relatively' softly compared to a turbo coming on boost thus giving the transmission and driveline a much easier time.i concede that even in a seic the body weight will have an impact on acceleration and thats where gear ratios come into play a bit (which admittedly i havent really looked into much yet-apart from the 6 speed!).I have been in a 650kg motor with a fireblade engine and it was suprisingly tractable at low rpm.dont get me wrong,it doesnt even compare to a low boost turbo,but its certainly usable.
i have a daily driver and now live 2 mins from work so i intend to make it a long term project, so engineering wise sorting out the timing chain/belt side isnt too much of a problem.picking the right cylinder head (for the bore size and spacing) however would be the major problem,and the ensuing machining to connect waterways etc...
bike engines in the 750-900 range have bore sizes of around 70mm with about 20mm less stroke.the larger stroke of the car bottom end would help keep the gas speed higher and fill in the bottom end torque a little together with the heavier reciprocating parts.these bike engines (even 10-12 years old) are making upwards of 125bhp.
in my warped and twisted head this option seems worth consideration when asking even the newer 16v fiat units to make 125bhp would take a fair amount of work.
Is there nobody out there that will fight my corner???..boo.hoo..
