Hi, I dont know if it is coincidence or not, but on Wed. i added a can of "CATACLEAN" to my "51" PUNTO 16v and as soon as i had done a few miles a missfire started. The missfire is really bad and is troughout the entire rev. range. I have replaced the plugs with NGK and have checked that they are all fireing by running the engine with the plug connected to the lead, but sitting on top the rocker cover so as to see the spark.
I am convinced that it must be a fuel problem. Could the Cataclean have affected the injectors or caused one to fail? Looking at the plugs that came out (NGK's) no 2 looked as though it hadnt been fireing. I understand that injectors are EXPENSIVE so did not want to risk buying a set, fitting them only to find that the missfire is still there.
Any advice appreciated.
Mike.
Mike.
