momoto33127
- Joined
- Mar 14, 2018
- Messages
- 5
- Points
- 3
Hello,
First, sorry for my bad english, I'm french...
I have a problem with my Stilo 1.9 8V JTD 115 with 310 000km, I haven't power...
I have power problems since I have the car, the 0 to 100 is done in 16-17 seconds
I tried to loosen the necklaces, I change a hose of the turbo (the one coming out of the intercooler), I try injector cleaners, nothing helps, or very little
I tested the injectors with the return in plastic cups, there is a maximum eccart of 12% , so it's good ?
My idle is very stable (between 848 and 852rpm)
The stem of the wastegate moves freely over several millimeters
No particular smoke, Only when I put the foot on the floor while being in neutral, when the engine arrives at 5000rpm big black cloud ca repaint the ground, but it is one of the rare case where it smokes
A few days ago, I condemned the EGR valve with an aluminum plate but this one did not resiste with the heat, so I put a flange for the JTDM (with holes in it), and I put another MAF sensor I had at home (a Chinese thing) and I unplugged the battery for 1 hour.
Since instead of having the turbo that starts to "well" push to the 1800rpm it grows rather 2200tr / min
So I gave the original MAF (bosch) but not much change, I put my plate(I redid a brass plate this time, the brass holds the heat better) instead of the flange of JTDM, it has not returned either as before ... I unplugged the battery 1h, nothing ... So basically, I returned to the normal configuration (just an aluminum flange and the original MAF sensor) and yet I did not get the turbo at 1800tr
I even had mismatches with the original MAJ, I made the decision to unplug it, and the car responded without clashes
I bought a new bosch MAJ sensor, I mounted it earlier, unplugged battery 1h, I found a lot of power, but still above 2200tr, before that, I do not have a lot, the car is soft under the 2200
I have a hole between 2800 and 3100rpm~
The pressure of my turbo is ok...
No error in MES...
This is my logs in attachments
yellow = RPM
grey = % accelerator
green = admission pressure goal
light blue = admission pressure measured
Orange = MAF goal in mg/i
dark blue = MAF measured in mg/i
We see that the measured airflow is half the objective... It's normal ?
A friend with a fiat grande punto 70ch jtdm sticks me behind in terms of performance ..
Another with a Citroen C4 90cv HDI 200 000km exceeds me very widely while they are cars with a relatively close weight...
Thank you!
No error in MES...
yellow = RPM
Thank you!
