Technical loosen electric connection in JTD stilo
Timppa83
Hi!
I found out that i have one loosen electric connection in my JTD stilo,can some one check if it supposed to be connected to somewhere.
It can be found under the diesel filter, there is big electric cable "hose" next to motor, those cables are coming from fuse box next to the battery and under the diesel filter wires for this connection is separated from that main cable hose.
here is some pictures to help for location.
It looks like the water in fuel sensor connector. It should plug into a sensor fitted in the bottom of the fuel filter. The sensor is item #3 in the diagram below.
Someone may have fitted the wrong filter without a sensor or the sensor may not have been refitted to the correct filter.
